Embedded Packet Capture question
b.kanani
Hi everyone
I have this strange problem with EPC on ASR1001: It works on some interfaces and it doesn't on others!
For example:
ASR-TEST__#moni cap buff MCBUFF
ASR-TEST__#moni cap po ip cef MCPOIN g0 both
ASR-TEST__#moni cap poin asso MCPOIN MCBUFF
ASR-TEST__#moni cap poin star all
Sending/Receiving some random traffic……..then
ASR-TEST__#sh moni cap buf MCBUFF
22:14:28.148 UTC Mar 20 2013 : IPv4 LES CEF    : Gi0 None
IT WORKS
Now if I make a small change:
ASR-TEST__#no moni cap po ip cef MCPOIN g0 both
ASR-TEST__#moni cap po ip cef MCPOIN g0/0/0 both
IT DOESN'T WORK!!!
They only difference that I can think of is, G0 is a management port and G0/0/0 is an interface port (on a SIP I guess)
I have tested this on 3 different IOS XE versions. All the same.
Has anyone had a similar experience?
What is the alternative to do a packet capture on ASRs? Apparently "debug ip packet" won't work.
paolo bevilacqua
You can contact Cisco to have them confirm that no packet capture is supported on management interface.
