Need info on "VRRP: Header ip address count sanity check failed" message
cireddy334
I am running VRRP on Cisco 2811 router (Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(15)T1), with another device.
i am getting following error message "VRRP: Header ip address count sanity check failed" on Cisco router, because of this Cisco router is always acting as Master even when priority of other device is more and other device is also acting as VRRP master.
The debug messages seen on Cisco 2811 router,
*May  2 12:13:37.043: VRRP: Grp 10 sending Advertisement checksum C9EB
*May  2 12:13:37.047: VRRP: Header ip address count sanity check failed
*May  2 12:13:39.995: VRRP: Grp 10 sending Advertisement checksum C9EB
*May  2 12:13:40.051: VRRP: Header ip address count sanity check failed
*May  2 12:13:42.783: VRRP: Grp 10 sending Advertisement checksum C9EB
*May  2 12:13:43.055: VRRP: Header ip address count sanity check failed
If i replace the Cisco with Juniper SSG 140 things are working with the same VRRP configuration.
Here is the information i need,
1. Why this error is coming on Cisco router
2. Do we have a solution for this issue
3. Or the other device is sending corrupted VRRP advertisiment packet
Test bed information
Cisco 2811 ------------------------------------------ Motorola Device
VRRP settings on Cisco 2811   (VRRP settings are same on Motorola device except higher priority is configured)
Router#show running-config
Building configuration...
Current configuration : 1606 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$R8O5$nO06IMmFZExQd0qRuOfoM0
no aaa new-model
ip cef
voice-card 0
no dspfarm
username symbol password 0 symbol
archive
log config
  hidekeys
track 10 interface FastEthernet0/0 line-protocol
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 10
ip address 172.16.10.2 255.255.255.0
ip nat inside
ip virtual-reassembly
vrrp 5 ip 172.16.10.10
vrrp 5 timers advertise 2
vrrp 5 priority 90
interface FastEthernet0/1.2
encapsulation dot1Q 5
ip address 172.16.15.2 255.255.255.0
ip nat inside
interface Dialer1
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username 08051504243_kk@airtelbroadband.in password 0 123456
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
ip nat inside source static 172.16.10.100 122.167.146.93
control-plane
line con 0
line aux 0
line vty 0 4
password symbol
login
line vty 5 15
password symbol
login
scheduler allocate 20000 1000
webvpn cef
end
cireddy334
Any information on this one is really helpful.
With Regards,
Channareddy
Do you have authentification for vrrp to the other side of network ?
