03-13-2006 07:43 AM - edited 03-03-2019 12:02 PM
hi
please help me in my config which is not working for RDP connection to my internal server.
I have 801 with DIAL UP ISDN connection i am using dynamic ip to connect. the config is below
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname DIAL-ISDN
enable secret level xxxx
ip subnet-zero
ip name-server x.x.x.x
isdn switch-type basic-net3
interface Ethernet0
ip address 192.168.0.123 255.255.255.0
ip nat inside
interface BRI0
no ip address
ip nat outside
encapsulation ppp
dialer pool-member 1
ppp authentication pap callin
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 500
dialer string 4004444
dialer hold-queue 10
dialer-group 1
ppp pap sent-username xxxx password xxxxx
ip nat inside source list 101 interface Dialer1 overload
ip nat inside source static tcp 192.168.0.100 3389 interface Dialer1 3389
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 101 permit ip any any
dialer-list 1 protocol ip permit
line con 0
password xxxx
login
transport input none
stopbits 1
line vty 0 4
password xxxx
login
length 100
no rcapi server
end
03-13-2006 08:18 AM
Just a thought - is the default gateway of the server set to be 192.168.0.123 ?
03-13-2006 09:05 PM
yes, the default gateway is 192.168.0.123
03-14-2006 12:33 AM
Hi shoeb
From where you are trying to connect to your RDP server ? are you trying to connect from the outside world ? if thts the case which public ip you are using up to establish the RDP connectivity ?
regds
03-14-2006 01:32 AM
if you type "sh int dialer1" and post the output. This should give you the dynamic address assigned. Check this is the address you are using.
Also, when you try and access the public address of the router/server on 3389 to access the server, where are you doing this from? Are you able to RDP to other "outside" servers - just wondering if your site is blocking RDP outbound.
There are no ACL lists so the NAT traslation should be sufficient.
