05-15-2006 10:48 PM - edited 03-03-2019 12:42 PM
We used 2611XM to connect remote site with 512K leased line.
Now, we have 10 more sites.
Could some one recommend a good router to use. I read that new routers can accommodate up to 4 WAN interfaces! We have (VOIP + VC + data).
I need the minimum router (28xx or 38xx).
05-15-2006 10:54 PM
Hi Friend,
I think 2811 will be ok for your network requirement
http://www.cisco.com/en/US/products/ps5881/index.html
HTH, if yes please rate the post.
Ankur
05-16-2006 02:55 AM
2811 comes with 64F/256R as standard.
Will this 256M serves the purpose. Please note that we have 4 WANs at the same time.
Which IOS I should use?
Thanks for the reply.
