Load balance on 2 ISDN line
d_unafraid
Hi All
My customer has subscribe to two ISDN line on a single router for backup in the event the main lease line is down, he is asking if internal traffic can be load balance on the two line? for Example http traffic to route through ISDN 1 and smtp traffic to route through ISDN 2?
what Cisco command can I used to set up such design method?
Thank you for all your time
rmujeeb81
You can use route map to implement above scenario. First of all you should make two extended access-lists, one for http and other for smtp traffic then this access list will match in route map. I n route map you should use " set ip-next hop " or " set ip interface " to route http traffic from ISDN1 and smtp traffic from ISDN2.
e.g route-map test permit 10
match address 101
set interface ISDN1
route-map test permit 15
match address 102
set interface ISDN2
Mujeeb
Ho Mujeeb, thank you so much. I will come back n rate the posting!
