Need suggestion for IOS of Cisco 3845
Sunil Patil
I have one Cisco 3845 Router. It has c3845-spservicesk9-mz.123-14.T4.bin IOS. I need to upgarde it with c3845-spservicesk9-mz.124-22.T5.bin because the old has been deffered on Cisco site.
I am facing one problem related to bandwidth shaping. In old IOS i am unable to configure 155 Mbps for Cisco router with 12.3 IOS. please check below
R1#    sh policy-map CTS-PUN-Parent-Out
  Policy Map PUN-Parent-Out
    Class class-default
      Traffic Shaping
         Average Rate Traffic Shaping
         CIR 154400000 (bps) Max. Buffers Limit 1000 (Packets)
      service-policy PUN-Child-Out
R1#
R1(config-pmap-c)#shape average ?
  <8000-154400000>  à Supports upto 150MB only
Can any one check that 12.4 IOS can support upto 155 Mbps. or suggest any other IOS.
For your reference i am also attaching Show Version of that box.
R1#sh version
Cisco IOS Software, 3800 Software (C3845-SPSERVICESK9-M), Version 12.3(14)T4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Thu 08-Sep-05 21:49 by kehsiao
ROM: System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
hostname uptime is 6 weeks, 3 days, 18 hours, 57 minutes
System restarted at 16:07:21 IST Sun Dec 25 2011
System image file is "flash:c3845-spservicesk9-mz.123-14.T4.bin"
use. Delivery of Cisco cryptographic produXXX does not imply
A summary of U.S. laws governing Cisco cryptographic produXXX may be found at:
export@cisco.com.
Cisco 3845 (revision 1.0) with 222208K/39936K bytes of memory.
Processor board ID
2 FastEthernet interfaces
2 Gigabit Ethernet interfaces
4 Serial(sync/async) interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
125184K bytes of ATA System CompactFlash (Read/Write)
Sunil
5 Replies 5
sfaizul
i have checked this as latest release hopefully it will work for you.
Description:SP SERVICES
Release Date:09/Dec/2011
File Name:c3845-spservicesk9-mz.151-4.M3.bin
Min Memory:DRAM 512 MB Flash 128 MB
Syed.
Hi Syed,
Thanks for your reply.
I just want one more information from you is c3845-spservicesk9-mz.124-22.T5.bin IOS support bandwidth shaping upto 155 Mbps or I will have to directly go for c3845-spservicesk9-mz.151-4.M3.bin Suggested by you.
Sunil
Hello Sunil,
I checked the 15.1(4)M and 15.2(2)T images but the shaping rate is the same for all of them:
  <1000-154400000>  Target Bit Rate (bits/sec). (postfix k, m, g optional;
                    decimal point allowed)
If you consider an upgrade, you should take into account that the 12.4(22)T (and the whole 12.4T train) is end of life.
Warm Regards,
Rose
HI Rozas,
Thanks for the information.
Can you please tell me which IOS i will prefered for upgradation to recover this problem.
Sunil
Hello Sunil,
Unfortunately, these are the latest IOS versions so even after upgrading (be that 12.4T or 15.1), the limitation would be the same.
Warm Regards,
Rose
