Need suggestion for Multi SA VTI
kashifkhan9407
I am planning to replace my old routers with ISR 4431 IOS-XE. In my design i have port channel configured through which multiple sub interfaces are configured.
The problem is that, crypto map are not supported on Port-channel interfaces. Due to it cisco has provided the workaround to implement multi SA VTI and according to cisco Multi SA vti are backward compatible with crypto map.
I need to know if someone has experience in establishing Sire-to-Site vpns between Multi SA vti on one side and crypto map on remote side.
Need you suggestion.
If other peer support vti why you not config
Loopback in both peer
Vti tunnel source and destination using loopback in both peer
Protect vti with ipsec profile
This skip the port channel crypto issue.
