Multilayer Switching
nonfko
i have been trying to finish this project for approx. 7 hours restarting and researching but nothing seems to help me establish a connection between vlan 10 and vlan 20 for example and make it able to ping successfully please help
balaji.bandi
There is a Typo mistake in IP address i guess ( or am i misgendering this wrong ?)
On L3 Switch
Create a VLAN
config t
Vlan 10,20,30,99
Interface vlan 99
ip address 192.168.99.254 255.255.255.0
Interface vlan 10
ip address 192.168.XX.254 255.255.255.0  (if this /23 correct the subnet and IP)
Interface vlan 20
ip address 192.168.XX.254 255.255.255.0  (if this /24 correct the subnet and IP)
I
interface vlan 30
ip routing
On the Sw connected interface
interface fas x/x
switchport mode trunk
On the each switch side same  access switch
config t
Vlan 10,20,30,99
Interface vlan 99
ip address 192.168.99.253 255.255.255.0
interface fas x/x
where the devices connected configured as per the device role
Interface fas x/x     (student)
switchport mode access
switchport access vlan 10
Interface fas x/x     (Teacher)
switchport access vlan 20
Interface fas x/x     (Admin)
switchport access vlan 30
BB
9 Replies 9
balaji.bandi
On L3 Switch
Create a VLAN
config t
Vlan 10,20,30,99
Interface vlan 99
Interface vlan 10
Interface vlan 20
I
interface vlan 30
ip routing
interface fas x/x
config t
Vlan 10,20,30,99
Interface vlan 99
interface fas x/x
BB
im not sure i understand this part
interface fas x/x
This on no L3 Switch side config :
BB
i have changed the ip addresses from 192.168.99.2 to 192.168.99.254 and now i seem to be able to ping all pc's!
without even doing anything else
Sure ..may we not have any visibility on what is configured on the devices. so that was my suggestion based on the information.
glad you able to resolve the issue or made a config as per your requirement.
BB
i have one more question, what about the vlan 99 am i supposed to assign vlan 99 to the 3 switches like i did with the laptops?
If you like to manage all Switches, then Switch required some Layer 3 SVI, so extend the VLAN to Switches, and create 1 spare IP address to each switch to connect using SSH.
BB
