Need to Allow a VLAN into a VRF
slad3s
The vlan has a SVI and I would like to get only this vlan or network into our VRF 500 so that everyone on said vlan can reach everything that VRF 500 can reach. We have a core switch that the SVI and VRF 500 exist on so I am trying to do some magic on this switch.
I thought I could so something like this below but I think this would only allow everyone in the VRF to reach the global routing table which is not what we need.
interface Vlan10
 description TEST
 ip address 10.1.10.1 255.255.255.0
 access-list 50 permit ip 172.17.0.0 0.0.255.255 10.1.10.0 0.0.0.255
route-map VRF_TO_GLOBAL permit 10
 match ip address 50
set global
interface Vlan500
 description VRF500
 ip vrf forwarding 500
 ip address 172.17.65.65 255.255.255.192
ip policy route-map VRF_TO_GLOBAL
Apologies if I am missing something obvious here. VRFs and what I am trying to do is very new to me. Any help would be greatly appreciated. Thank you!
flamingbk
Hello!
Try do this:
ip vrf VRF500
rd 1:1
import ipv4 unicast map GLOBAL_TO_VRF
export ipv4 unicast map VRF_TO_GLOBAL
route-target export 1:1
route-target import 1:1
ip prefix-list vlan10 seq 5 permit 10.1.10.0/24
ip prefix-list vrf seq 5 permit 172.17.65.64/26
route-map GLOBAL_TO_VRF permit 10
match ip address prefix-list vlan10
match ip address prefix-list vrf
router bgp 1
bgp log-neighbor-changes
address-family ipv4
redistribute connected
address-family ipv4 vrf VRF500
network 172.17.65.64 mask 255.255.255.192
At this point you can see the route 172.17.65.64 pointed to SVI 500 via BGP in Global routing table and in the VRF500 routing table you will see a route 10.1.10.0/24 pointed to SVI10 via BGP.
Hello
So why don't you put vlan 10 in the vrf 500 also?
Kind Regards
Paul
This is what I'm wondering also.
are this issue solve?
