Need to block a multicast route due to mfib exhaustion on N9k
Chris Knipe
Hi, I am having some issues after a core migration with multicast.  The core that we migrated to supports a maximum of 8k multicast routes and we are currently exceeding that amount due to traffic from UPNP (239.255.255.250) coming from our wireless clients.  There is an SVI on the 9k for these wireless clients and I have tried appling different types of ACL's to this wireless vlan, but I still see these clients from this vlan show up after applying the acl and clearing the multicast routes. Is there a way that I can create a route map to deny this multicast route from showing up in the routing table?
6 Replies 6
I think on the Nexus 9K, for multicast traffic, you need a port ACL inbound. It would look something like this:
ip access-list DENY_UPNP
10 deny ip any 239.255.255.250/32
20 deny ip 239.255.255.250/32 any
30 permit ip any any
interface Vlan20
ip port access-group DENY_UPNP in
Hello
As this is a routed interface do you have pim enabled? -  if so why not just remove it from that svi?
Res
Paul
Kind Regards
Paul
In this particular instance, it is because we are just wanting to block UPnP address as the subscribers to this address are exceeding the number of multicast routes available on the platform.  Though we would still like to have multicast working for other apps for users on this subnet.
bwilson
Did that ACL end up working for you, or did you find another solution?
Feds
Hi Chris,
Which solution did you implement?
Thanks!
Giuseppe Larosa
Hello @Chris Knipe ,
you can use TTL scoping for this I did this in the past.
All the UPNP (239.255.255.250) is just noise but they should have TTL limited
You can put a barrier using an high value of IPv4 TTL like 32 or 64 to block the noise.
This means that all the wanted sources have to increase their TTL to a greater value. You can check this using VideoLAN VLC.
Other options if you are using auto-rp is an interface level
ip pim rp auto-rp listener  <acl>
command that can be used to filter out the noise.
Hope to help
Giuseppe
