need to nat without nat protocol unify router > cisco 2960S
kermitsfrog0
Alright so.... I'm struggling a bit here and trying to see if I have any options before we just need to get rid of the 2960s and get a new router....
We have a unify router with internet access providing a LAN subnet of 172.16.46.0/24.
I have a 2960s assigned to 172.16.46.149 and its able to reach the internet just fine.
the problem I'm facing now is that there is no 'nat' capabilities in the router and no 'routing' options either it seems. google says I should be able to enable routing with the 'ip routing' command but this shows as an invalid command - google then suggests using the 'sdm prefer lanbase-routing' command, which also shows as an invalid command....
Do I have any valid options here?
Hello @kermitsfrog0 ,
>> WS-C2960S-24TS-L = LAN Base
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-s-series-switches/data_sheet_c78-726680.html?dtid=osscdc000283
as already suggested you can add a router to provide routing and NAT and you can use the Catalyst 2960S a L2 access switch
Hope to help
Giuseppe
6 Replies 6
kermitsfrog0
This is in reference to the 2960s in case it wasn't clear.
use show version
if you device is a Catalyst 2960 there is no NAT capabilities on it
depending on the model ip routing can be enabled witth the command ip routing .
post show version to get better help .
if it is a LAN base model it might be limited to L2 switch features
Hope to help
Giuseppe
Switch#sh ver
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 12.2(53)SE2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 21-Apr-10 06:08 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01B00000
ROM: Bootstrap program is Alpha board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(53r)SE, RELEASE SOFTWARE (fc3)
Switch uptime is 18 minutes
System image file is "flash:/c2960s-universalk9-mz.122-53.SE2/c2960s-universalk9-mz.122-53.SE2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960S-24TS-L (PowerPC) processor (revision B0) with 131072K bytes of memory.
Processor board ID FOC1503X065
Last reset from power-on
3 Virtual Ethernet interfaces
1 FastEthernet interface
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : C0:62:6B:92:9B:80
Motherboard assembly number : 73-11910-06
Power supply part number : 341-0328-02
Motherboard serial number : FOC15017A97
Power supply serial number : DCA1432M4JJ
Model revision number : B0
Motherboard revision number : A0
Model number : WS-C2960S-24TS-L
Daughterboard assembly number : 73-11933-04
Daughterboard serial number : FOC15022537
System serial number : FOC1503X065
Top Assembly Part Number : 800-30954-02
Top Assembly Revision Number : A0
Version ID : V02
CLEI Code Number : COMGG00ARB
Daughterboard revision number : A0
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 28 WS-C2960S-24TS-L 12.2(53)SE2 C2960S-UNIVERSALK9-M
Configuration register is 0xF
Switch#
Hope to help
Giuseppe
crap. alright, off to get an ISR instead... thank you Giuseppe.
Hello
I the 2960s is a layer2 switch it has no routing capabilities and no NAT function, so if you require both features on a single device then a rtr would be applicable and you could still use the2960s as a access-layer device for end users connectivity
Kind Regards
Paul
