Need to remove VPN tunnel interface
ud0508500
I need to remove a VPN IPSEC tunnel interfcae..crypto maps associated as well..I did not know the exact order as to what I needed to remove first...
appreciate the help!
interface Tunnel8 (SITE IS CLOSED)
description "GRE Tunnel"
bandwidth 3000
ip address x.x.x.x 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1420
ip flow ingress
ip route-cache flow
no ip mroute-cache
keepalive 5 4
tunnel source Loopback1
tunnel destination x.x.x.x
ip access-list extended Trafficto
permit ip host x.x.x.x host x.x.x.x
crypto isakmp key VPN!$ address x.x.x.x
crypto map ToRemote 8 ipsec-isakmp
description "VPN to VPN"
set peer x.x.x.x set transform-set TransformSet
match address TraffictoVPN
a.alekseev
Level 7
Level 7
remove crypto map form interfaces
remove crypto map, acl, isakmp key
remove tunnel interface
that was easy...many thanks once again..
appreciate the help
