need to understand bgp
vishalpatil86
hi,
following BGP config -
interface GigabitEthernet0/0
description ****Last Mile1 ABCDL****
ip address xx.xx.xx.30 255.255.255.252
duplex full
speed 100
interface GigabitEthernet0/1
description ****Last Mile2 EFRGH****
ip address xx.xx.xx.34 255.255.255.252
duplex full
speed 100
nterface Vlan1
ip address yy.yy.yy.225 255.255.255.240
router bgp 11111
no synchronization
bgp log-neighbor-changes
network yy.yy.yy.224 mask 255.255.255.240
neighbor xx.xx.xx.29 remote-as 22222
neighbor xx.xx.xx.29 route-map traffic-II in
neighbor xx.xx.xx.33 remote-as 22222
neighbor xx.xx.xx.33 route-map traffic-I out
no auto-summary
ip prefix-list POOL seq 10 permit yy.yy.yy.224/28
route-map traffic-I permit 10
match ip address prefix-list POOL
set as-path prepend 11111 11111 11111
route-map traffic-II permit 20
set local-preference 160
snmp-server community mlkhs RO
snmp-server community itprivate RW
snmp-server community public RO 60
snmp-server contact goagsh
i need to understand what the config is.....
pls help me on this
vishalpatil86
i am having very less idea about bgp, but with the aboveh config i may come to know te concept
In layman, you are influencing the route to be prefered; from where traffic should be incoming to your network.
Smitesh
Hi Vishal
The above BGP config is related to a dual-homed peering to an ISP 22222 whereby we want to use only1Link(ABCDL-
xx.xx.xx.29) for Active Traffic Forwarding and Receiving
To achieve the same we are maniulating the default BGP Attributes.
On peering  xx.xx.xx.29 we are making the Local-Preference which is the 2nd Criterion for best path selection to be higher than the default 100 so when any traffic which has to go out from this router selects the rouets learned from this peer as next-Hop.
To achieve the above we are binding a route-map " traffic-I " to the peer xx.xx.xx.29 in inbound direction to match the entwrok and set its LP as 160
On peering  xx.xx.xx.33 we are making the AS-Path which is the 3rd Criterion for best path selection
to be increased than default of preferring the lowest AS path for any route so that when the receiving end peer receives the route it does not select this route as compared to peer xx.xx.xx.33 and hence again all the traffic will be sent to this router via peer xx.xx.xx.29
To achieve the above we are binding a route-map " traffic-II " to the peer xx.xx.xx.33 in outbound direction to match the prefix which we are advertising via network statement  via the prefix list POOL   and increase its AS-length
Hoe this helps you to understand the config.
Varma
