What are the minimum parameters to configure a T1 between two 1841 router?
tremblmi
I configure two WIC-1DSU-T1-v2 interfaces with a T1 crossover cable. What are the mimimum configurations to do to communicate from LAN1 (int fa0/0 of one 1841 router) to LAN2 (int fa0/0 of the second 1841 router) ?
Do I need a routage protocole ? And if yes wich one ? Interne or externe (RIP or BGP) Or static route is enough ?
Also, is that I should put a encapsulation, like ppp ? Is it neccessary on a point to point line ?
Finally what about the following commands, do I need it ?
service-module t1 clock source internal
service-module t1 timeslots 1-24 speed 64
service-module t1 framing esf
service-module t1 linecode b8zs
thank you
2 Accepted Solutions
Pulkit Nagpal
Jon Marshall
Micheline
To answer your question about routing. You do need to have routes on each router for the LAN subnets. These can be static routes or you can use a dynamic routing protocol. Note unless you are peering with an ISP or using MPLS you generally don't need to run BGP.
So with statics and with EIGRP as examples -
192.168.5.0/24 -> fa0/0 R1  192.168.10.1/30 -> T1 -> 192.168.10.2/30 R2 fa0/0 192.168.6.0/24
statics
R1
ip route 192.168.6.0 255.255.255.0 192.168.10.2
R2
ip route 192.168.5.0 255.255.255.0 192.168.10.1
EIGRP
R1
router eigrp 10
network 192.168.5.0 0.0.0.255
network 192.168.10.0 0.0.0.3
no auto-summary
R2
router eigrp 10
network 192.168.6.0 0.0.0.255
no auto-summary
Jon
paolo bevilacqua
Have you considered searching this forum and/or  reading documentation  before asking so many common questions ?
Or, even better, hire a professional to configure it right.
Pulkit Nagpal
Hi Micheline,
Please use following discussion for reference:
https://supportforums.cisco.com/message/501041#501041
https://supportforums.cisco.com/message/19309#19309
https://supportforums.cisco.com/message/3466585#3466585
Pulkit Nagpal
Technical Community Manager - NI
Jon Marshall
Micheline
statics
R1
R2
EIGRP
R1
router eigrp 10
no auto-summary
R2
router eigrp 10
no auto-summary
Jon
Thank you to those who gave me useful answers that allowed me to advance in my knowledge of the configuration of a T1. Finally, it is rather easy to configure and I am proud to have raised and realise this challenge.
