Need to use both links at same time for site-to-site vpn
salman abid
i'm having some cofussion that i have 2 internet connections and i want to use them as ACTIVE & STANDBY or both can load share at the same time with site to site vpn configuration
if i configure gateway of vlans on multilayer switch then how can i configure HSRP or if i do PBR then how it can be???????????
Devices:
cisco 881 router with 5mbps link
cisco 837 router with 2mbps link
cisco 3560x multilayer switch
Abzal
Level 7
Level 7
Hi Salman,
Here is simple config for VPN backup on Head office:
crypto ipsec transform-set XX esp-3des esp-sha-hmac
crypto map MAP-A 100 ipsec-isakmp
set peer 2.2.2.2
set peer 1.1.1.1
set transform-set XX
match address vpn-to-branch
And on Branch you could configure HSRP on routers for failover.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
salman abid
symbolic requirement plan is attached already above
can any one help me???????????????
Abzal
Level 7
Level 7
Hi Salman,
set peer 2.2.2.2
set peer 1.1.1.1
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
@abzal
thanx for reply
i'll do the same and if i found some more help i'll come back to u
