Need two internet connection. Primary backup. Both on Ethernet. Both with static ip address
touristsis
Hi Everyone,
I have a cisco router 1721 with 3 ethernet connection.  1 for LAN.  2 for Wan (Both with static ip address).  Can someone help me?  I have most of it program, but missing some commands.  Here is what I have.  Please Help!
ip name-server 216.16.193.251
ip name-server 216.16.195.2
ip dhcp excluded-address 192.168.150.1 192.168.150.149
ip dhcp excluded-address 192.168.150.181 192.168.150.254
ip dhcp pool test
   network 192.168.150.0 255.255.255.0
   domain-name bcs-ip.net
   dns-server 192.168.150.248 192.168.150.249
   default-router 192.168.150.254
   lease 7
ip cef
interface Ethernet0
description att dsl
ip address 99.99.xx.xx 255.255.255.248
ip nat outside
half-duplex
interface Ethernet1
description cable Internet
ip address 98.98.xx.xx 255.255.255.248
ip nat outside
half-duplex
interface FastEthernet0
description cisco test lan
ip address 192.168.150.254 255.255.255.0
ip nat inside
speed auto
half-duplex
router rip
network 99.0.0.0
network 98.98.0.0
network 216.16.200.0
ip default-gateway 99.99.x.x
ip nat inside source list 1 interface Ethernet0 overload
ip nat inside source list 2 interface Ethernet1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 99.x.x.x
no ip http server
access-list 1 permit 192.168.150.0 0.0.0.255
access-list 2 permit 192.168.150.0 0.0.0.255
banner motd ^CDO NOT MESS WITH THIS ROUTER UNLESS YOU KNOW WHAT THE HELL YOU ARE
DOING AND THAT YOU ARE AN EMPLOYER OF CISCO TEST^C
line con 0
password XXX
login local
transport preferred none
line aux 0
password XXX
login local
line vty 0 4
password XXX
login local
no scheduler allocate
end
ciscotest#
Ganesh Hariharan
Hi Everyone,
ip dhcp pool test
   lease 7
ip cef
interface Ethernet0
description att dsl
ip nat outside
half-duplex
interface Ethernet1
ip nat outside
half-duplex
For your requirement check out the below link for IOS nat load balancing for ISP
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a00808d2b72.shtml
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
