Netflow configuration assistance required !!! please assist
suhailpuri
Hi all,
Below is the show ver of 6509 switch , please i need some assistance how to enable netflow
sh ver
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(33)SXI7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Mon 18-Jul-11 05:50 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX7, RELEASE SOFTWARE (fc1)
sw-cta1-c6-bc uptime is 1 year, 20 weeks, 6 days, 22 hours, 24 minutes
Uptime for this control processor is 1 year, 20 weeks, 6 days, 21 hours, 50 minutes
Time since sw-cta1-c6-bc switched to active is 1 year, 20 weeks, 6 days, 21 hours, 49 minutes
System returned to ROM by  power cycle at 00:55:44 UTC Fri Aug 12 2011 (SP by power on)
System restarted at 13:56:59 CEST Mon Aug 29 2011
System image file is "sup-bootdisk:s72033-ipservicesk9_wan-mz.122-33.SXI7.bin"
Last reload reason: reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.5) with 983008K/65536K bytes of memory.
Processor board ID SMC152900JG
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
3 Virtual Ethernet interfaces
194 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
sw-cta1-c6-bc#
suhailpuri
i configured as per below but i cannot retrieve statistics for traffic netflow shows 97 kbps traffic on vlan 219 but its a ten gig interface
mls netflow
mls flow ip interface-full
int vlan 219
ip route-cache flow
ex
ip flow ingress layer2-switched vlan 219 , 31
mls nde sender version 5
ip flow-export source vlan 219
ip flow-export destination 10.65.18.156 9996
ip flow export layer2-switched vlan 219 ,31
also i cannot enable ip route-cache flow on ten gig interfaces
sw-cta1-c6-bc(config)# int te1/1
sw-cta1-c6-bc(config-if)#ip rou
sw-cta1-c6-bc(config-if)#ip route
sw-cta1-c6-bc(config-if)#ip route-ca
sw-cta1-c6-bc(config-if)#ip r?
rsvp  rtp
