snmp wan connection
Hi every one
I have a doubt. how to add a device to an SNMP community?.
I mean the community already exists and it is already monitorizing by a PC (monitoring tests are performed in implemantacion possible).  and there are several teams that are monitored, but is thought to put other devices for monitoring, which makes me wonder: how do new devices could be added?  Do I have to configure any ACL?
Greetings.
Hello Johnnatan
No quite sure what you are asking  regards snmp setup but below is the basic requirements for NMS access on a switch/router
There are various optional values that can be utilised for snmp setup, but for basic snmp you will need to specify snmp server host and snmp-server communities with community string values.
The remote device specified by either an ip addresss or hostname will be the destination (NMS)that your switch/router will send snmp notifications too ( Network management systems)
snmp-server host 10.10.10.10 mycomstring (the community-string is like a password)
Then you can use different access values via different community strings with either Read&write (RW) or Read-Only(RO) to permit access to snmp on your switch/router
snmp-server community RWstring1 RW (read-write)
snmp-server community ROstring2 RO ( read-only)
This could be further controlled by acl's to permit certain networks access
access-list 10 permit ip 10.10.10.0 0.0.0.255
snmp-server community RWstring1 RW 10
Please look at this:
http://www.cisco.com/en/US/docs/ios/12_1/configfun/command/reference/frd3001.html#wp1022436
res
Paul
Kind Regards
Paul
mircea.alicu
I use this to monitor my routers and sw on a cacti server:
snmp-server community mycommunityname RO
snmp-server host 10.10.10.2 version 2c mycommunityname
