I am trying to get a flow exporter to work on a Cisco ASR 1000. I get flow traffic on the monitor, but it does not appear to be forwarding to the exporter correctly. I have tried v4 and v9. I have also tried setting the interface to send input traffic, output traffic, and both. I don't know if the issue is that I am using a vrf for the export port, the fact that the monitored ports and the exporter port are on different networks, or something else entirely.
#sh flow monitor NetFlow statistics
Cache type: Normal (Platform cache)
Cache size: 200000
Current entries: 808
High Watermark: 947
Flows added: 10177
Flows aged: 9369
- Active timeout ( 60 secs) 421
- Inactive timeout ( 15 secs) 8948
#sh flow exporter NetFlow statistics
Flow Exporter NetFlow:
Packet send statistics (last cleared 2d23h ago):
Successfully sent: 0 (0 bytes)
Client send statistics:
Client: Flow Monitor NetFlow
Records added: 0
Bytes added: 0
Here is the relevant config:
destination (internal IP address) vrf netflow
source GigabitEthernet0/0/0
transport udp 9996
export-protocol netflow-v9
template data timeout 60
exporter NetFlow
cache timeout active 60
record netflow-original
interface GigabitEthernet0/0/0
description Management/Netflow
vrf forwarding netflow
ip address (internal IP address)
negotiation auto
interface TenGigabitEthernet0/1/0
description Uplink
ip address (external IP address)
ip flow monitor NetFlow input
