Vlan connection
JimmyTurene5116
Hello I would like you to help me, I have a cisco router RV345 I created two vlan on it Vlan1: 10.0.1.1 Untagged Vlan2: 10.0.2.1 Tagged, then I activated inter-vlan connection, I  plugged my router into a Cisco SG250-50 switch in the Gigabit Ethernet port that I put in trunk mode, I added both vlan too When I connect two computers in my switch I can't ping between the two vlans, but when I put the computers on the same vlan the ping to walk, can you help me to connect the two vlans between them?
GRANT3779
Doe the trunk port on the switch also have vlan 2 as "native" / untagged?
No, i just configured the Gigabit ethernet port as trunk.
luis_cordova
Hi @JimmyTurene5116 ,
Just to discard, have you disabled the firewall before pinging?
On occasion, the firewall blocks ping from external networks.
