Netflow On Tunnel interface
GRANT3779
Hi All,
If I have the following Tunnel Interface with IP flow Egress configured. Should I be able to see traffic conversations egressing the Tunnel Interface or has encryption happened by this point? I'm not seeing any traffic and wondering if I have my flow commands in the wrong place. Netflow in general is working as If I add the "ip flow" commands to say the LAN Interface I start seeing traffic. I'm really only interested in specific traffic though and certain tunnels
interface Tunnel1
 description TestTunnel
 ip address 172.27.240.69 255.255.255.252
 ip mtu 1400
 ip flow egress
 ip virtual-reassembly
 qos pre-classify
 tunnel source FastEthernet0/0
 tunnel destination x.x.x.x
 tunnel protection ipsec profile TEST
#sh run | sec flow
ip flow-cache timeout active 1
ip multicast netflow rpf-failure
 ip flow egress
ip flow-export version 5
ip flow-export destination 172.16.3.9 2055
ip flow-top-talkers
 top 10
 sort-by bytes
Cisco Freak
Level 9
Level 9
Please use the command ' ip route-cache flow ' under the tunnel interface to enable netflow in that interface.
ip flow ingress and egress commands are only for the physical interfaces.
CF
