Netflow : sh ip cache flow empty, sh ip flow interface empty
phone.cam
I have 2 routers connected together
1rst router is nominal =>  Cisco 1841, "flash:c1841-spservicesk9-mz.124-15.T12",  Version 12.4(15)T12
2nd router is used as backup=>  CISCO881-K9, c880data-universalk9-mz.150-1.M4.3,
Netflow is implemented on twice router
1rst router,  netflow is down
2nd router,Netflow is runnning
1rst router  configuration
ip flow-cache timeout active 10
ip flow-export source Vlan3
ip flow-export version 9
ip flow-export destination 10.147.96.xx 2055
privilege exec level 5 show flow-sampler
privilege exec level 4 show ip flow
interface ATM0/0/0
 description ORCH=RESEAU -- Interface WAN
bandwidth 640
no ip address
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
interface Vlan3
description ORCH=CLIENT -- RESEAU INTERCO FIREWALL1 --
ip address 10.148.125.1xx 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
service-policy output REMARKING-COS-OUT
n1#sh ip cache flow
IP packet size distribution (0 total packets):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608
IP Flow Switching Cache, 278544 bytes
0 active, 4096 inactive, 0 added
0 ager polls, 0 flow alloc failures
Active flows timeout in 10 minutes
Inactive flows timeout in 15 seconds
IP Sub Flow Cache, 25800 bytes
0 active, 1024 inactive, 0 added, 0 added to flow
0 alloc failures, 0 force free
1 chunk, 2 chunks added
last clearing of statistics never
Protocol Total Flows Packets Bytes Packets Active(Sec) Idle(Sec)
-------- Flows /Sec /Flow /Pkt /Sec /Flow /Flow
SrcIf SrcIPaddress DstIf DstIPaddress Pr SrcP DstP Pkts
n1#sh ip flow interface
//does not display any netflow interface
Can somebody help me?
Thanks for your help
Best regards
0 Replies 0
