Who can tell me which cisco product support dlsw now?
xh_liu
 My customer have some DLSW config on a Cisco 2811 router, but now Cisco 2811 router is EOS and EOL,it means the product can't get any support service now.
My customer don't want to change original DLSW config in futrure new device.
So I try to find a new Cisco device which can support DLSW and replace the old Cisco 2811.
But I didn't find a suitable such device.
Who can give me any suggestion about the question?
Thank you!
Seb Rupik
Hi there,
The recommended replacement for the 2811 is the 2911, checking the Cisco feature navigator shows the new device has support for DLSw, DLSw V2 and DLSw+ :
http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/by-feature-technology.jsp
cheers,
Seb.
As Seb mentioned, the next level is a 29xx router but you should verify if it is compatible and the EOL or EOS as well.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Yes, I have noticed the 2900 router, but 'Cisco announces the end-of-sale and end-of-life dates for the Cisco 2900 Series Integrated Services Routers. The last day to order the affected product(s) is December 9, 2017. '
So is there any other option??
