Netflow Version 5 or 9? + Configuration on a Cisco 6500
Matthew burnley
Hello Everyone,
I have a few questions regarding Netflow and I’m hoping you guys can help me out.  We have an internet facing 6500 Layer 3 switch running BGP, i want to turn on Netflow and capture a sample of all the traffic on the interfaces that connect us to other Autonomous Systems (AS's) in a bid to ascertain where the traffic is going, or  to which AS our traffic is going outbound.
I obviously want to use sampling so i propose 1 in every 512 packets to be sent to the Netflow server, now my dilemma is do i configure Netflow with the usual commands or do i use the:
ip cef
flow-sampler-map netflowexport
mode random one-out-of 512
interface fastethernet0/0
ip route-cache cef
flow-sampler netflowexport
ip flow-cache timeout active 1
ip flow-cache timeout inactive 15
ip flow-export source Loopback0
ip flow-export version 9 origin-as
ip flow-export destination 150.150.150.2 9996
snmp-server ifindex persist
Or
Switch(config)#mls netflow
Switch(config)#mls flow ip full
Switch(config)#mls nde sender version 5
mls sampling packet-based 512
mls aging long 300
mls aging normal 120
is the MLS commands just to enable Netflow for layer 2 exports?
Also i have a choice between version 5 and 9, i want to monitor traffic inbound and outbound on an interface, i have read on the internet that exports only work in one direction on version 5?
Does anyone know any decant windows based Netflow software that is value for money and supports monitoring of traffic between autonomous systems? - I’m about to trial Scrutinizer Netflow Analyser.
Many thanks for your ideas/suggestions.
Matt.
Robert Falconer
mls netflow enables netflow collection on the PFC
ip route-cache flow enables netflow on the MSFC for a particular interface and all subinterfaces.
Netflow 5 only works for inbound flows. Version 9 allows you to specify flow egress from an interface as well.
I've used Scrutinizer in the past and been pretty happy with it. I've also used Solarwinds.
