Netgear Adsl Modem and Cisco 2800 Router
ciscomoon
I have netgear adsl modem and cisco 2800 router which i would like to configure.
My isp has given username and password. I need to know how do i configure Cisco 2800 Router.
Here is my basic setup:
1. ADSl line going into netgear modem
2. Crossover cable from netgear to Cisco 2800 router FE0/0.
3. Straight cable from Cisco 28000 router FE0/1 into 5 port Switch.
I would like to bring this router up and running so that i can use other 4 pcs.
Please give me the step by step commands so that i can configure.
My ISP has given PPPOE authentication username and pass.
6 Replies 6
vincent-n
Level 3
Level 3
Why don't you use the Netgear for the ISP authentication? It's easier to do it that way.
Thanks for the reply as per your instructions i have don the authentication in modem. now can you please let me know the commands so that i can use the cisco 2800 router.
Please give step by step commands. I want to use 192.168.0.1
thanks
any experts in forum?
it might be easiest if you post the configuration of the 2800 you have so far, we can then make the necessary additions/amendments.
GNT
Current configuration : 826 bytes
version 12.3
hostname srinivas
boot-start-marker
boot-end-marker
no network-clock-participate aim 0
no network-clock-participate aim 1
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
interface FastEthernet0/0
ip address dhcp
ip nat outside
shutdown
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 124.254.72.6
ip http server
ip nat inside source list 102 interface FastEthernet0/0 overload
access-list 102 permit ip 192.168.0.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Any Suggesstions
