Network and Vlan no internet
Hello Everyone!
Merry Christmas  !!!
This will be my first post here and I bit exacted . I am kind of beginner in Cisco networking. I am trying to build something as Soho network. I have a problem with topology  and I can not find where is my wrong.
I can not connect my V LAN 's to internet, but most of the host communicated together
I would like to apologies if my questions is too stupid but i need to know where is my wrong
Thank you in advance!
Cisco 2651 and switch 2950 24
You can see the configuration of my network here-
User Access Verification
Password:
Router_1>en
Router_1#show i p route
Gateway of last resort is 192.168.0.1 to network 0.0.0.0
C 192.168.10.0/24 is directly connected, Fast Ethernet 0/1.1
172.16.0.0/24 is sub netted, 1 sub nets
C 172.16.1.0 is directly connected, Fast Ethernet 0/1
C 192.168.20.0/24 is directly connected, Fast Ethernet 0/1.2
C 192.168.0.0/24 is directly connected, Fast Ethernet 0/0
S* 0.0.0.0/0 [254/0] via 192.168.0.1
Router_1#show access-
Router_1#show access-l
Router_1#show access-lists
Standard IP access list 1
permit 172.16.1.0, wildcard bits 0.0.0.255 (15094 matches)
permit 192.168.0.0, wildcard bits 0.0.0.255 (4019 matches)
permit 192.168.10.0, wildcard bits 0.0.0.255 (15 matches)
permit 192.168.20.0, wildcard bits 0.0.0.255 (5 matches)
Router_1#show run
Building configuration...
Current configuration : 1599 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Router_1
ip subnet-zero
ip dhcp excluded-address 172.16.1.1 172.16.1.10
ip dhcp pool soho
network 172.16.1.0 255.255.255.0
default-router 172.16.1.1
dns-server 8.8.8.8
call rsvp-sync
!interface FastEthernet0/0
ip address dhcp
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip address 172.16.1.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
ip nat inside
interface FastEthernet0/1.2
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
ip nat inside
interface Serial1/0
no ip address
shutdown
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface Serial1/4
no ip address
shutdown
interface Serial1/5
no ip address
shutdown
interface Serial1/6
no ip address
shutdown
interface Serial1/7
no ip address
shutdown
ip nat inside source list 1 interface FastEthernet0/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.1 254
no ip http server
access-list 1 permit 172.16.1.0 0.0.0.255
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 192.168.20.0 0.0.0.255
dial-peer cor custom
!Router_1#show ip nat t
Router_1#show ip nat st
Router_1#show ip nat statistics
Total active translations: 3256 (0 static, 3256 dynamic; 3256 extended)
Outside interfaces:
FastEthernet0/0
Inside interfaces:
FastEthernet0/1, FastEthernet0/1.1, FastEthernet0/1.2
Hits: 1024259 Misses: 13107
Expired translations: 9110
Dynamic mappings:
-- Inside Source
[Id: 1] access-list 1 interface FastEthernet0/0 refcount 3256
Also I will give more info witch network communicate each other
172.16.1.1ping 192.168.0.1
172.16.0.0 ping 192.168.10.1
172.16.1.1 ping 192.168.20.1
All vlan 's is ping between them
192.168.0.1 not ping 172.16.0.1 – not work
vlan's
192.168.10.1
192.168.20.1 can ping all pc with linux, printers, android device
from 192.168.0.1 network, but can not ping pc with win 10 from some network.
192.168.0.1 – ping 192168.10.1 and 192.168.20.0 does not work
No internet on the vlans
There is internet on 172.16.1.0 lan
192.168.0.1
Thank you in advance!!!
3 Accepted Solutions
on a side note, I assume you have an ISP modem connected to the 2651 ?
Remove the line 'access-list 1 permit 192.168.0.0 0.0.0.255' from your access list, as this is the subnet you use to connect to the uplink. Also, you might as well want to add dhcp pools for your Vlans.
So the entire config should look like this (important parts marked in bold):
version 12.2
hostname Router_1
ip subnet-zero
ip dhcp excluded-address 192.168.10.1
ip dhcp excluded-address 192.168.20.1
ip dhcp pool soho
dns-server 8.8.8.8
ip dhcp pool VLAN10
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 8.8.8.8
ip dhcp pool VLAN20
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
dns-server 8.8.8.8
call rsvp-sync
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
ip nat inside
ip nat inside
interface Serial1/0
no ip address
shutdown
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface Serial1/4
no ip address
shutdown
interface Serial1/5
no ip address
shutdown
interface Serial1/6
no ip address
shutdown
interface Serial1/7
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 dhcp
no ip http server
@MarkoAnastasov45813 Hello again..
Please, make changes below;
no ip route 0.0.0.0 0.0.0.0 192.168.0.1 254
no access-list 1
which device is 192.168.0.1? It your switch? or your Modem?
You will need create three routes back to your router on this device to your VLAN's.
Log on this device 192.168.0.1 and create three routes, like below;
ip route 172.16.1.0 255.255.255.0 192.168.0.49
ip route 192.168.10.0 255.255.255.0 192.168.0.49
ip route 192.168.20.0 255.255.255.0 192.168.0.49
I think that you didnt my suggestion, try again.
Jaderson Pessoa
*** Rate All Helpful Responses ***
Hello Georg!
Job done!
Massive help! Thank you! I appreciate it!
This is the config and work perfect!
Also thank you of all of you guys!!
Also thank you of all of you guys!!!
!ip dhcp excluded-address 172.16.2.1 172.16.2.20
ip dhcp pool Route_2
network 172.16.2.0 255.255.255.0
default-router 172.16.2.1
dns-server 8.8.8.8
ip dhcp pool 10
dns-server 8.8.8.8
ip dhcp pool 20
dns-server 8.8.8.8
call rsvp-sync
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
interface BRI0/0
no ip address
encapsulation hdlc
shutdown
ip address 172.16.2.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip nat inside
ip nat inside
ip nat inside source list marko interface FastEthernet0/0 overload
ip classless
ip http server
ip access-list standard marko
permit 172.16.2.0 0.0.0.255
19 Replies 19
Hello
Config looks okay apart from your default gateway, try the following
sent from iphone
Kind Regards
Paul
Hello Paul.Thank you so much. I will try it now.
version 12.2
hostname Router_1
ip subnet-zero
ip dhcp pool soho
dns-server 8.8.8.8
ip dhcp pool VLAN10
dns-server 8.8.8.8
ip dhcp pool VLAN20
dns-server 8.8.8.8
call rsvp-sync
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
ip nat inside
ip nat inside
interface Serial1/0
no ip address
shutdown
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface Serial1/4
no ip address
shutdown
interface Serial1/5
no ip address
shutdown
interface Serial1/6
no ip address
shutdown
interface Serial1/7
no ip address
shutdown
ip classless
no ip http server
Hello Georg! I am starting with now config right now . Thank you very much!
We will be in touch!
Hello Georg!
Job done!
dns-server 8.8.8.8
ip dhcp pool 10
dns-server 8.8.8.8
ip dhcp pool 20
dns-server 8.8.8.8
call rsvp-sync
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
interface BRI0/0
no ip address
encapsulation hdlc
shutdown
ip nat inside
duplex auto
speed auto
ip nat inside
ip nat inside
ip classless
ip http server
Jaderson Pessoa
@MarkoAnastasov45813 hello
no access-list 1
ip route 172.16.1.0 255.255.255.0 (ip of your interface FastEthernet0/0 on your router)
ip route 192.168.10.0 255.255.255.0 (ip of your interface FastEthernet0/0 on your router)
ip route 192.168.20.0 255.255.255.0 (ip of your interface FastEthernet0/0 on your router)
and post here the result.
Jaderson Pessoa
Hello Jaderson! Thank you for your advice .
Yes 192.168.0.1 is a my home router. let me start with new config and I will keep in touch!
Hello guys!
I am still fighting with this.
Much appreciate your help. Thank you!
When I try to apply some of this :
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 dhcp  ---I Lost the connection with internet.
I believe that  FastEthernet0/0 dhcp is with ip 192.168.0.49.
permit 172.16.1.0, wildcard bits 0.0.0.255 (628 matches)
I still go it :
C 192.168.10.0/24 is directly connected, FastEthernet0/1.1
172.16.0.0/24 is subnetted, 1 subnets
C 172.16.1.0 is directly connected, FastEthernet0/1
C 192.168.20.0/24 is directly connected, FastEthernet0/1.2
C 192.168.0.0/24 is directly connected, FastEthernet0/0
hostname Router_1
ip subnet-zero
ip dhcp pool soho
dns-server 8.8.8.8
call rsvp-sync
ip address dhcp --- No ip here ??
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
ip nat inside source list 1 interface FastEthernet0/0 overload - how to delete  this one
ip classless
no ip http server
show
you need to delete the static route you have in place, in global config mode:
--> no ip nat inside source list 1 interface FastEthernet0/0 overload - how to delete this one
ip classless
--> no ip route 0.0.0.0 0.0.0.0 192.168.0.1 254
no ip http server
and add the static route:
ip route 0.0.0.0 0.0.0.0 FastEtheernet0/0 dhcp
Router_1#conf t
Router_1(config)#no ip nat inside source list 1 interface FastEthernet0/0 overload
Router_1(config)#no ip route 0.0.0.0 0.0.0.0 192.168.0.1 254
Router_1(config)#ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 dhcp
Hi Georg.
I much apprentice your help. Respect
I did it.
and I  have it  :
Router_1>en
Router_1#config
Configuring from terminal, memory, or network [terminal]?
Enter configuration commands, one per line. End with CNTL/Z.
Router_1(config)#$nside source list 1 interface FastEthernet0/0 overload
% Invalid input detected at '^' marker.
Router_1(config)#ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 dhcp - this is worried me
Also i do not have internet access
this is done -
ip classless
no ip http server
Router_1#show ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is not set -- ???
just configure:
without the 'dhcp' keyword at the end...
Hi buddy!
Yes now command is work. Thank you.
but unfortunately still not internet.
#show ip route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S* 0.0.0.0/0 is directly connected, FastEthernet0/0
Hi buddy!
but unfortunately still not internet no where
#show ip route
Did you do my suggestion?
to see what ip address of your interface... try commands below;
show ip interface brief
show ip arp
Jaderson Pessoa
