Network and Vlan no internet
Hello Everyone!
Merry Christmas  !!!
This will be my first post here and I bit exacted . I am kind of beginner in Cisco networking. I am trying to build something as Soho network. I have a problem with topology  and I can not find where is my wrong.
I can not connect my V LAN 's to internet, but most of the host communicated together
I would like to apologies if my questions is too stupid but i need to know where is my wrong
Thank you in advance!
Cisco 2651 and switch 2950 24
You can see the configuration of my network here-
User Access Verification
Password:
Router_1>en
Router_1#show i p route
Gateway of last resort is 192.168.0.1 to network 0.0.0.0
C 192.168.10.0/24 is directly connected, Fast Ethernet 0/1.1
172.16.0.0/24 is sub netted, 1 sub nets
C 172.16.1.0 is directly connected, Fast Ethernet 0/1
C 192.168.20.0/24 is directly connected, Fast Ethernet 0/1.2
C 192.168.0.0/24 is directly connected, Fast Ethernet 0/0
S* 0.0.0.0/0 [254/0] via 192.168.0.1
Router_1#show access-
Router_1#show access-l
Router_1#show access-lists
Standard IP access list 1
permit 172.16.1.0, wildcard bits 0.0.0.255 (15094 matches)
permit 192.168.0.0, wildcard bits 0.0.0.255 (4019 matches)
permit 192.168.10.0, wildcard bits 0.0.0.255 (15 matches)
permit 192.168.20.0, wildcard bits 0.0.0.255 (5 matches)
Router_1#show run
Building configuration...
Current configuration : 1599 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Router_1
ip subnet-zero
ip dhcp excluded-address 172.16.1.1 172.16.1.10
ip dhcp pool soho
network 172.16.1.0 255.255.255.0
default-router 172.16.1.1
dns-server 8.8.8.8
call rsvp-sync
!interface FastEthernet0/0
ip address dhcp
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip address 172.16.1.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
ip nat inside
interface FastEthernet0/1.2
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
ip nat inside
interface Serial1/0
no ip address
shutdown
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface Serial1/4
no ip address
shutdown
interface Serial1/5
no ip address
shutdown
interface Serial1/6
no ip address
shutdown
interface Serial1/7
no ip address
shutdown
ip nat inside source list 1 interface FastEthernet0/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.1 254
no ip http server
access-list 1 permit 172.16.1.0 0.0.0.255
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 192.168.20.0 0.0.0.255
dial-peer cor custom
!Router_1#show ip nat t
Router_1#show ip nat st
Router_1#show ip nat statistics
Total active translations: 3256 (0 static, 3256 dynamic; 3256 extended)
Outside interfaces:
FastEthernet0/0
Inside interfaces:
FastEthernet0/1, FastEthernet0/1.1, FastEthernet0/1.2
Hits: 1024259 Misses: 13107
Expired translations: 9110
Dynamic mappings:
-- Inside Source
[Id: 1] access-list 1 interface FastEthernet0/0 refcount 3256
Also I will give more info witch network communicate each other
172.16.1.1ping 192.168.0.1
172.16.0.0 ping 192.168.10.1
172.16.1.1 ping 192.168.20.1
All vlan 's is ping between them
192.168.0.1 not ping 172.16.0.1 – not work
vlan's
192.168.10.1
192.168.20.1 can ping all pc with linux, printers, android device
from 192.168.0.1 network, but can not ping pc with win 10 from some network.
192.168.0.1 – ping 192168.10.1 and 192.168.20.0 does not work
No internet on the vlans
There is internet on 172.16.1.0 lan
192.168.0.1
Thank you in advance!!!
19 Replies 19
Hi!
Please see fowling:
Router_1#show ip in
Router_1#show ip interface br
Router_1#show ip interface brief
FastEthernet0/0 192.168.0.49 YES DHCP up up
FastEthernet0/1 172.16.1.1 YES NVRAM up up
FastEthernet0/1.1 192.168.10.1 YES NVRAM up up
FastEthernet0/1.2 192.168.20.1 YES NVRAM up up
Serial1/0 unassigned YES NVRAM administratively down down
Serial1/1 unassigned YES NVRAM administratively down down
Serial1/2 unassigned YES NVRAM administratively down down
Serial1/3 unassigned YES NVRAM administratively down down
Serial1/4 unassigned YES NVRAM administratively down down
Serial1/5 unassigned YES NVRAM administratively down down
Serial1/6 unassigned YES NVRAM administratively down down
Serial1/7 unassigned YES NVRAM administratively down down
Router_1#
Router_1#
Router_1#
Router_1#
Router_1#show ip arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 192.168.0.49 - 000e.837a.8f80 ARPA FastEthernet0/0
Internet 192.168.10.1 - 000e.837a.8f81 ARPA FastEthernet0/1.1
Internet 192.168.0.1 0 400d.1060.10e0 ARPA FastEthernet0/0
Internet 192.168.20.1 - 000e.837a.8f81 ARPA FastEthernet0/1.2
Internet 172.16.1.22 5 3065.ec7e.4226 ARPA FastEthernet0/1
Internet 172.16.1.1 - 000e.837a.8f81 ARPA FastEthernet0/1show
Router_1#show protocols
Global values:
Internet Protocol routing is enabled
FastEthernet0/0 is up, line protocol is up
Internet address is 192.168.0.49/24
FastEthernet0/1 is up, line protocol is up
Internet address is 172.16.1.1/24
FastEthernet0/1.1 is up, line protocol is up
Internet address is 192.168.10.1/24
FastEthernet0/1.2 is up, line protocol is up
Internet address is 192.168.20.1/24
Serial1/0 is administratively down, line protocol is down
Serial1/1 is administratively down, line protocol is down
Serial1/2 is administratively down, line protocol is down
Serial1/3 is administratively down, line protocol is down
Serial1/4 is administratively down, line protocol is down
Serial1/5 is administratively down, line protocol is down
Serial1/6 is administratively down, line protocol is down
Serial1/7 is administratively down, line protocol is down
Hello.
I have one more 2651 router and I can try him with brand new config.
What do you think?1!?
Thank you for your help for all of you!!!
@MarkoAnastasov45813 Hello again..
Please, make changes below;
no ip route 0.0.0.0 0.0.0.0 192.168.0.1 254
no access-list 1
which device is 192.168.0.1? It your switch? or your Modem?
You will need create three routes back to your router on this device to your VLAN's.
Log on this device 192.168.0.1 and create three routes, like below;
ip route 172.16.1.0 255.255.255.0 192.168.0.49
ip route 192.168.10.0 255.255.255.0 192.168.0.49
ip route 192.168.20.0 255.255.255.0 192.168.0.49
I think that you didnt my suggestion, try again.
Jaderson Pessoa
*** Rate All Helpful Responses ***
Hello Jaderson. Thank you so much for your help.
I unrestrained what do you mean but my home router does not give me opportunity to do it. It is very simply and not much manageable unfortunately. I will try to find other way to do it. Probably I will connect my to 2651 router together and after that I will try to play with next hop and also I will put L3 switch 3650 .
This is my first CCNA lab and probably need time to be set up, but I am sure to be ready soon.
Thank you very much for your help and help from Paul and Georg!!!
Hello Georg!
Job done!
Massive help! Thank you! I appreciate it!
This is the config and work perfect!
Also thank you of all of you guys!!
Also thank you of all of you guys!!!
!ip dhcp excluded-address 172.16.2.1 172.16.2.20
ip dhcp excluded-address 192.168.10.1
ip dhcp excluded-address 192.168.20.1
ip dhcp pool Route_2
network 172.16.2.0 255.255.255.0
default-router 172.16.2.1
dns-server 8.8.8.8
ip dhcp pool 10
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 8.8.8.8
ip dhcp pool 20
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
dns-server 8.8.8.8
call rsvp-sync
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
interface BRI0/0
no ip address
encapsulation hdlc
shutdown
ip address 172.16.2.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip nat inside
ip nat inside
ip nat inside source list marko interface FastEthernet0/0 overload
ip classless
ip http server
ip access-list standard marko
permit 172.16.2.0 0.0.0.255
