Network Audit
jopetik09
There will be a audit on my customer enterprise network (setup and devices config) by external vendor.
Before the audit by external vendor, I need to make sure that everything is fine and no holes as I am managing my customer network. If something find out by external vendor then there are chances that my customer may blame me.
Is there any free downloaded tools to do this.
OR
can someone help me how to achieve this.
Jopeti.
7 Replies 7
ameya_oke
Hi Jopeti,
Nipper is a good audit tool.
http://www.techrepublic.com/blog/security/audit-your-cisco-routers-security-with-nipper/276
please rate if helpful.
Ameya
Hi Ameya,
I logged into SourceForge.net but have not see any Nipper exe or file like that.
Can you give me the exact path or link.
Jopeti.
For time being please download free evaluation software and work with it
https://www.titania-security.com/nipper/evaluate
I will give thepath soon.
Please rate the helpful posts.
Ameya
Hi Ameya,
I managed to download nipper from SourceForge.net only.
It is nipper-ipcalc-1.0.0
But i am not able to go this from command prompt. Below is what i am getting.
Can you provide any step by step how we can use. Of course it is there techrepublic.com but I am not getting through.
C:\>cd nipper-ipcalc-1.0.0
The directory name is invalid.
C:\>cd nipper
The system cannot find the path specified.
C:\>
Jopeti.
Hi Jopeti,
This link is not the correct path,i shared that link for info on nipper.
I have the toolwith me at my workplace, i can share it with you tomorrow.
If it is very urgent please try searching on web, i am trying to find but it will take a while.
please rate the helpful posts.
Ameya
Hi Jopeti,
PLease check your private mail section.
Ameya
Hi Ameya,
Jopeti.
