03-28-2005 11:41 AM - edited 03-03-2019 09:09 AM
Hello all,
I have a 3745 Router with IOS ver 12.3(7)T and I have another Router (2621 model ) which have a card with 10Base T/AUI port .Will this card work with 3745 Router with IOS 12.3 (7) .
Thanks with regards,
Raju
03-28-2005 03:13 PM
What card do you have on the 2600 ?
03-29-2005 02:12 AM
It's normal Ethernet card . In sh ver , it shows as
"Ethernet/IEEE 802.3 interface " which has AUI/UTP (10Base-T) port.
Raju
03-29-2005 02:40 AM
I believe you have an NM-1E card, which is not compatible with 3700 series. See this document:
http://www.cisco.com/warp/public/765/tools/quickreference/portadapters.pdf
These tools may be helpful:
Dynamic Configuration Tool
Software Advisor (CCO logon required)
http://tools.cisco.com/Support/Fusion/index.do
HTH,
Mustafa
03-29-2005 04:20 AM
Thanks mustafa . It's NM-1E card.
