03-27-2005 10:39 PM - edited 03-03-2019 09:09 AM
I have 2 main offices and several branches. Plz take a look network diagram in the attachment file.
The Internet connection come through the HQ to Telco and Telco continue providing to others branches at the provices.
The question is how to configure load balancing on EIGRP protocol on the HQ's Router, because when one of our branches(e.g. Branch C) access to the SERVERS located at HQ, the connection is very slow. It seems it goes through both interface of the router of HQ. But when I shutdown the interface s0/1 of HQ's router, the connection seem works fine, because the connection will go through to the main office A only.
I would like HQ>>>>>>>>A as Primary
HQ>>>>>>>>Telco as Secondary
Any solution would be appreciated.
Thanks in advance.
Sakdavin
03-28-2005 04:13 PM
There is no attachment.
03-28-2005 05:22 PM
hello,
Sorry for not attaching the file.There was something wrong.
Anyway, plz find the other Load Balancing On EIGRP posted below, coz as I remember I had posted 2 times(One with the attachment, and the other one without attachment).
Thank you in advance.
Sakdavin
03-29-2005 03:49 AM
equal cost or unequal cost??
simplest way is
router eigrp 1
network x.x.x.x
variance 2
traffic-share balanced
You can also use
traffic-share min across-interfaces
min - is use to send traffic only across minimum cost path, it will ignore multiple paths in routing table.
