Network comes to a halt adding IPs to VLAN
BashedRoot
Level 2
Level 2
Ok, installed brand new 3650 L3 switches last week, replacing some older Cisco 3750s. Been adding and removing VLANs and large quantity of IPv4 addresses without issues. Observium shows less than 20% CPU/RAM usage, everything is fine there. For some oddball reason tonight, I was trying to add a /29 subnet to one of the VLANS already there, as secondary subnet. The very second I do this, my entire network crawls to a halt and stays that way even for over 15 minutes, literally everything public but my access in the switch remains normal (?). The very second I remove that secondary subnet that was added, network immediately returns to normal. NOT NORMAL!
I replicated this with different VLANS and also entirely different C class subnets. Same issue, very strange and never seen this ever happen even on the old 3750s. Why is this happening suddenly on the new, far more powerful 3650's especially after a week with no problems at all, I'm baffled and need to know.
Any help would greatly be appreciated.
Info:
- replicated 2 different VLANS, 2 different C classes entirely
- CPU 20%
- 2 x 3650 switches stacked
- not network backbone issue at all, total throughout is between 80-150MBPs. My burstable is 300Mbps.
- been using these switches since Saturday without issues
- Model: WS-C3650-24TS (both switches)
5 Replies 5
cisco_lad2004
Level 5
Level 5
Are you able to run a debug while adding the /29 ?
Could it be case of duplicate IP configured on another node ?
If not, it is indeed odd !
Not duplicate IPs at all.
Here's what I found out from Cisco tech, not sure how to resolve this.
++ you were adding secondary ip address on interface vlan, once you applied the command the network became slow and he got the following errors:
*Sep 14 09:03:48.129: %L3UNICAST_ERRMSG-3-fib_err: 1 fed:  FIB installation failure for unicast route: No Hardware Resource Available
*Sep 14 09:03:57.958: %L3UNICAST_ERRMSG-3-fib_err: STANDBY:2 fed:  FIB installation failure for unicast route: No Hardware Resource Available  (Cisco3650-2)
++ we took packet captures before and after applying the commands, we can clearly see that there are TCP retransmissions after the connection malfunctioned.
++ i checked the tcam utilization and noticed the "Directly or indirectly connected routes" is almost full:
CAM Utilization for ASIC# 0
Table                                              Max Values        Used Values
Directly or indirectly connected routes            16384/7168       16127/7168
++ i checked the SDM templates available for this platform, i found both "advanced" template and "VLAN" template allocate same number for Directly or indirectly connected routes.
++ checking this deeply, we are hitting a hardware limitation with the 3550. There are two different SDM templates you can have for the 3650 and they are referenced in the link below. From the documentation though there is no template that will support more than 7168 masks and you are exceeding that value. In order to go away from this you are going to have to better summarize your routes and get the number of indirectly connected routes down.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/3se/system_management/configuration_guide/b_sm_3se_3650_cg/b_sm_3se_3650_cg_chapter_01100.html
Hi;
Can you try to upgrade/downgrade the Cisco recommend software, may be some unreported bug is hitting on the software version you are running.
Thanks & Best regards;
I removed nearly 1,000 routed IPs and I still cannot even add a single /29 back on despite not coming close to the max allowance. Cisco support is useless.
 Unicast MAC addresses                              32768/512         169/22
 Directly or indirectly connected routes            16384/7168       15784/7168
 L2 Multicast groups                                4096/512           0/7
 L3 Multicast groups                                4096/512           0/9
 QoS Access Control Entries                         3072                52
 Security Access Control Entries                    1536               190
 Netflow ACEs                                        768                15
 Input Microflow policer ACEs                        256                 7
 Output Microflow policer ACEs                       256                 7
 Flow SPAN ACEs                                      512                13
 Control Plane Entries                               512               240
 Policy Based Routing ACEs                          1024                 9
 Tunnels                                             256                 9
 Input Security Associations                         256                 4
 Output Security Associations and Policies           256                 9
 SGT_DGT                                            4096/512           0/0
 CLIENT_LE                                          4096/64            0/0
 INPUT_GROUP_LE                                     6144                 0
 OUTPUT_GROUP_LE                                    6144                 0
hard to find any documentation for the issue you are describing. You might want to try and change the MTU setting on your VLAN interface (1500 is the default) to something else, such as 1000, or 1400:
Switch(config)#interface vlan 100
Switch(config-if)#ip mtu 1000
