Network connectivity over 2 hops
thewrench
I have three networks. the ones that are attached 1-2 and 2-3 are connected. I can not ping networks 1 and 3 either way? I tried to put static routes in but will not connect or see each other.. ?? Any Ideas...
Richard Burts
George
There is really not enough information here for us to give you good answers. Would you post the output of show ip interface brief, the configuration of the static routes that you have done, and the output of show ip route?
If we had that (and the identification of the addresses that you are attempting to ping) then we might be able to give you better answers.
Rick
Rick
shivlu jain
Level 5
Level 5
please provide the all details to get the good output.
regards
shivlu
