ā07-28-2015 04:59 AM - edited ā03-05-2019 01:57 AM
Hello everyone,
I hope one of you can give me some advice on the following question. On this moment we have 3 offices in the US and 1 office in the Netherlands. We want to connect the the offices via a 100mbit IPSEC VPN connection. I have the knowledge to create the VPN connections but i do not know what kind of Cisco equipment we need. Our offices in the US already have an Cisco 3725 without an VPN module, our office in the Netherlands uses an ASA 5510 for internet and VPN connections. I expect that the 3725 is not fast enough to create an VPN connection like that.
What would you guys suggest / do in this situation?
With kind regards,
Arnoud Stolk
ā07-28-2015 05:42 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
A 3725 is on the light side for even 100 Mbps, unencrypted. Without encryption hardware, your 3725s would be crushed with multi-megabit encryption.
I not familiar enough with the ASA series to comment on their encryption performance.
I've attached a Cisco whitepaper that discusses performance of most of the newer ISRs, including using for encryption.
ā07-28-2015 07:38 AM
ipsec vpn asa 5510 throughput is about 170 mbps
http://www.cisco.com/c/en/us/products/collateral/security/asa-5500-series-next-generation-firewalls/prod_brochure0900aecd80402e39.html
ā07-28-2015 11:55 PM
Thank you for the answers, can one of you tell me if it is better to put a new router on all the locations or a ASA on all the locations?
