Advertising Multiple Networks with BGP
patrick.peters
I'm getting ready to change my IPv4 address space over to a new provider.  I run BGP with multiple ISPs, so I figured I'd just start advertising the new network in my BGP configuration (in addition to my existing network) and slowly migrate my services from one address space to another.
I added the network statement for the new IPv4 class C network and noticed the first strange thing.  I added
network 207.191.52.0 mask 255.255.255.0
but when I do a "show run" I see
router bgp 14385
 no synchronization
 bgp log-neighbor-changes
 network 63.94.231.0 mask 255.255.255.0
The mask I specified seems to have for my new network seems to have gone away.  If I look at the routes I'm advertising to my neighbors, I also see unexpected results:
#sho ip bgp nei  207.235.39.229 advertised-routes
BGP table version is 5029, local router ID is 207.235.39.230
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 63.94.231.0/24   0.0.0.0                  0         32768 i
*> 207.191.52.0     0.0.0.0                  0         32768 i
Total number of prefixes 2
Once again, the mask for my new network seems to be missing.
I've done a soft reset with my neighbors.  None of the looking glass servers I have queried seem to see an advertisement for my new network.
My full BGP configuration:
router bgp 14385
 no synchronization
 neighbor 64.47.18.173 remote-as 19855
 neighbor 64.47.18.173 soft-reconfiguration inbound
 neighbor 64.47.18.173 filter-list 22 out
 neighbor 66.55.46.182 remote-as 7224
 neighbor 66.55.46.182 password 7 xxxxxxx
 neighbor 207.235.39.229 remote-as 4323
 neighbor 207.235.39.229 soft-reconfiguration inbound
 neighbor 207.235.39.229 filter-list 22 out
 no auto-summary
ip as-path access-list 22 permit ^$
I'm running:
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 15.0(1)M6, RELEASE SOFTWARE (fc1)
on a 2811 router.
I'm at a loss for why this network isn't being picked up by my ISP's, but I'm guessing it has something to do with that subnet mask.  Any suggestions are appreciated.  I don't work with BGP very often, so I'm a little rusty...
Thanks!
2 Accepted Solutions
Patrick,
You are seeing this because your network, 207.191.52.0/24 is a Class C network so BGP is leaving the mask off.  If you were to advertise 207.191.52.0/29, you would see the mask in your advertisement and in the BGP table.  Here is a snippet that shows what I'm referring to:
R10#show run int lo207
Building configuration...
Current configuration : 68 bytes
interface Loopback207
 ip address 207.191.52.1 255.255.255.0
end
R10#show run int lo208
Current configuration : 70 bytes
interface Loopback208
 ip address 208.191.52.1 255.255.255.248
end
R10#show run | sec router bgp
router bgp 10
 network 208.191.52.0 mask 255.255.255.248
 neighbor 155.1.108.8 remote-as 8
R10#
R10#
R10#show ip bgp neighbor 155.1.108.8 advertised-routes
BGP table version is 3, local router ID is 150.1.10.10
              r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
              x best-external, a additional-path, c RIB-compressed,
RPKI validation codes: V valid, I invalid, N Not found
 *>  208.191.52.0/29  0.0.0.0                  0         32768 i
Scott
Hello
Thats becasue the 207 191.52.0 is by default a class c network and it doesnt require a subnet mask statement
If this class C address that was being cidr'd ( i giuess this isnt te correct terminology) using a different subnet range other than the default 24 network bits then you would need to add the subnet mask in the bgp process.
res
Paul
Kind Regards
Paul
Patrick,
end
end
router bgp 10
R10#
R10#
Scott
Thanks!  It's good to know that I didn't mess up the config.
Now I just need to figure out why the advertisement doesn't seem to be propagating..  But that's a whole different issue.
Hello
res
Paul
Kind Regards
Paul
