Network Re-Design ?'s
our organisation presently have (2) 1841 Moduler Router and (15) Unmanageble Switches and (1) Cisco 2950 Switch with (250 )PC's.my question's are as follows.
1) can we create 20 subinterface to support 20 vlans on 1841 router (yes/No)
2)can we configure 20 vlan on 2950 switch and connect each vlan port to unmanageble switch so that the unmanageble switch will in one VLAN.(Yes/No)
3)will be ther any issue if i do this type of network design.
Kiran Kumar CH
yes you are right
Narayan
5 Replies 5
royalblues
Level 10
Level 10
1. Yes
2. Yes, 20 vlans are configurable
3. I would prefer to use a L3 switch rather than defining subinterfaces for each vlan as a router on a stick design
Narayan
Hi Narayan,
i would like to know if i connect a unmanageble switch to one of the VLAN Port of the managed cisco switch will it be okey
Kiran Kumar CH
yes it is ok .... but all the ports in that unmanageabe switch need to be on one vlan
Narayan
Hi Narayana,
Please look at the attached doc,
so u mean to say the unmanageble switch will be only the part of that perticular vlan port rt.
yes you are right
Narayan
