Network
Nadersarieddine
Please advise best Switch to connect 5 to 6 lap tops for Network games.
royalblues
Level 10
Level 10
Will they be connected to anything else or you just need to conenct only these laptops.
i think a 2960G would be sufficient for you
C2960G-24-TS-S
Narayan
Hi Narayan,
Thanks for your support, yes laptops to be connected alone. Is C2960G-24-TS-S for wireless connection also?
No you cannot use C2960G-24-TS-S as a wireless access point.
you can connect a wireless access point to one of the ports and use it though
HTH,
Narayan
