Networking Project Help
daniel_growth
Hi All,
Below is a picture of my topology,
The file to the packet tracer is also attached. All password or logins are admin and cisco.
I would like DEV and Management network traffic to route through the firewall when access the corp network.
I have yet to configure the router and firewall as i'm not sure in what to do.
My other question is VLAN 10 and 20 can not cross communicate. This is the way i want it, but should i also put ACLS to reinforce this rule as best practice?
Kind Regards,
Daniel!
Kind Regards,
Daniel Growth
35 Replies 35
Also S4 to S1 is painfully slow. I have checked my RAM and it is not hardware related. This must be the way the devices are configured.
Switch>en
Switch#ping 10.10.10.1
Sending 5, 100-byte ICMP Echos to 10.10.10.1, timeout is 2 seconds:
Success rate is 60 percent (3/5), round-trip min/avg/max = 483/791/946 ms
Kind Regards,
Daniel Growth
the problem is that interfaces GigabitEthernet1/2 and 1/3 are both configured with the sane address space. A 'real' ASA would not let you do that. It causes OSPF to form an adjacency with S2, which is in 'standby' state. Shut down the interface:
interface GigabitEthernet1/3
shut
No luck.
Switch#ping 192.168.1.1
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Kind Regards,
Daniel Growth
so from S1 you are able to ping 10.10.15.20 and 10.10.15.21 ?
Yes that is successful. I can do that from S4 also.
Kind Regards,
Daniel Growth
@Georg Pauwen
I will attach my newest file. I am struggling with pinging to the 172 address from the switches and back.
TACACS/Radius will not seem to work on switches
HSRP standby IP's are complaining
The firewall needs the G1/2-3 interfaces fixing.
If you could help id really appreciate it.
Kind Regards,
Daniel Growth
