New Cisco 1921 doesn't display running configuration
Nirmal Singh
Hi All,
I've recently received this new Cisco 1921 routers with Cisco CP loaded, so it comes up with the annoying change username and password at first access. I've removed all of those files from the flash memory, and rebooted it, and it came up with the proper initial configuration dialog, which is what I wanted.
But, whenever I configure the router with a set of basic configuration, like interface, routing, and snmp loggings, and hit wr mem, it doesn't display at all when I do "sh run". It's weird cause when I do sh run | sec rip  or any other stuff that I have configured, it shows up , but not in sh run at all.
What's the deal with the new routers??? Even sh version doesn't show the config-register or memory allocation details. Which is weird!
xxxxx#sh ver
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 20-Mar-12 17:58 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
xxxxxx uptime is 6 minutes
System returned to ROM by reload at 06:39:25 UTC Mon Apr 29 2013
System restarted at 06:40:59 UTC Mon Apr 29 2013
System image file is "usbflash0:c1900-universalk9-mz.SPA.151-4.M4.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
xxxxx#sh run
Building configuration...
Current configuration : 1930 bytes
! Last configuration change at 06:42:46 UTC Mon Apr 29 2013
version 15.1
service password-encryption
hostname xxxxxx
boot-start-marker
boot-end-marker
logging userinfo
logging buffered 4096
no aaa new-model
no ipv6 cef
ip source-route
ip cef
xxxxxxx #sh run | sec rip
router rip
version 2
network 172.17.0.0
network 192.168.10.0
network 192.168.13.0
no auto-summary
xxxxxxx#sh license feature
Feature name             Enforcement  Evaluation  Subscription   Enabled  RightToUse
ipbasek9                 no           no          no             yes      no
securityk9               yes          yes         no             no       yes
datak9                   yes          yes         no             no       yes
SSL_VPN                  yes          yes         no             no       yes
ios-ips-update           yes          yes         yes            no       yes
WAAS_Express             yes          yes         no             no       yes
6 Replies 6
Leo Laohoo
What's the output to the command "sh hardware"?
Have you tried upgrading the IOS?  Could be a bug.
Same stuff, but I do have another router that's working fine when I do a sh run.
Problematic router:
xxxxxx#sh hardware
xxxxx uptime is 1 hour, 35 minutes
Working router:
yyyyyyy#sh ver
yyyyyyy uptime is 1 week, 3 days, 10 hours, 19 minutes
System restarted at 06:19:19 est Fri Apr 19 2013
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1921/K9 (revision 1.0) with 491520K/32768K bytes of memory.
Processor board ID FGLxxxxxx
2 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
249840K bytes of USB Flash usbflash0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO1921/K9          FGLxxxxxx
Technology Package License Information for Module:'c1900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
data          None          None           None
And same IOS?
yes, see above
Never seen this before.
I don't know about others, but try a different IOS.  If the behaviour is the same, raise a TAC Case.
Alternatively, try this first:
conf t
config-registry 0x2102
end
reload
rcpoemrvt
That's because you probably pressed an arrow key when there was standing "--More--". You have to type the enter key.
