New Cisco 881 License Issues
clyded
I have two new 881 units and it appears that the crypto engine is not running on both units.  Logs show that it is not even trying to connect.  The MN=CISCO881-Sec-K9 V01 and I have bought these units in the past (1-2 years ago) and the advsecurity license was on by default.  I have had no problems in the past with these units.  The new Cisco license model has changed this to a more complecated task.
Now it seems like you have to tell the unit to use this IOS, but after jumping through all of these hoops it still states that it needs a reboot (did this several times and it state the same thing).  I have read many blogs of people having simular issues, but no answer.  Does anyone know how to fix this issue?
I entered in the "lic boot mod c880-data level advsecurity"  command and all aof the "end user" license agreement commands as well....
and rebooted the unit .... still does not work....
License Information for 'c880-data'
    License Level: advsecurity   Type: Permanent
    Next reboot license Level: advsecurity
sho lic
Index 1 Feature: advipservices
        Period left: Life time
        License Type: Permanent
        License State: Active, Not in Use
        License Count: Non-Counted
        License Priority: Medium
Index 2 Feature: advsecurity
        License State: Active, In Use
Index 3 Feature: ios-ips-update
        Period left: Not Activated
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Not in Use, EULA not accepted
        License Priority: None
Index 4 Feature: SSL_VPN
        License Count: 0/0  (In-use/Violation)
sho lic feat
Feature name             Enforcement  Evaluation  Subscription   Enabled  RightToUse
advipservices            yes          yes         no             no       yes
advsecurity              no           no          no             yes      no
ios-ips-update           yes          yes         yes            no       yes
SSL_VPN                  yes          yes         no             no       yes
sho ver
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.0(1)M8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 16-Feb-12 02:58 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
VPN881 uptime is 18 minutes
System returned to ROM by reload at 17:05:04 CST Thu Jan 16 2014
System restarted at 17:05:36 CST Thu Jan 16 2014
System image file is "flash:c880data-universalk9-mz.150-1.M8.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 881 (MPC8300) processor (revision 1.0) with 236544K/25600K bytes of memory.
Processor board ID FTX162****
5 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
256K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO881-SEC-K9       FTX16*****C
clyded
here is the crypto info.....
crypto isakmp policy 1
encr aes 256
authentication pre-share
crypto isakmp key xxxxxxxx address xx.xx.xx.xx
crypto ipsec transform-set 123 esp-aes 256
crypto map test-CMap 10 ipsec-isakmp
set peer xx.xx.xx.xx
set transform-set 123
match address xx
interface FastEthernet4
description WAN
ip address xx.xx.xx.xx  255.255.255.252
shutdown
duplex auto
speed auto
sho crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
IPv6 Crypto ISAKMP SA
sho crypto engine bri
        crypto engine name:  Virtual Private Network (VPN) Module
        crypto engine type:  hardware
                     State:  Enabled
              Product Name:  Onboard-VPN
                FW Version:  1
              Time running:  2059 seconds
               Compression:  Yes
                       DES:  Yes
                     3 DES:  Yes
                   AES CBC:  Yes (128,192,256)
                  AES CNTR:  No
     Maximum buffer length:  4096
          Maximum DH index:  0050
          Maximum SA index:  0050
        Maximum Flow index:  0100
      Maximum RSA key size:  0000
        crypto engine name:  Cisco VPN Software Implementation
        crypto engine type:  software
             serial number:  F50******
       crypto engine state:  installed
     crypto engine in slot:  N/A
