Newbie IPSec:I try to set transform, but I get "Error-tag does not exist"
news2010a
Level 3
Level 3
Hi, anyone can tell me what's wrong with the entry below?
RouterB(config-crypto-map)#set transform set myset
ERROR: transform set with tag "set" does not exist.
So far this is what I have entered onto RouterB:
show run
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key cisco address 10.0.0.1
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto map test 1 ipsec-isakmp
! Incomplete
set peer 10.0.0.1
Jon Marshall
You need a hyphen ie.
set transform-set myset
Jon
Jon Marshall
Jon
Still the same issue occurred even though hyphen added
A-END(config-crypto-map)#set transform-set myset
ERROR: transform set with tag myset does not exist.
A-END#
dcarlton
It should be "set transform-set myset".
