Multiple VLAN on router with DHCP
Student HoGent
Hey, I am a student and new to Cisco packet tracer.
I am trying to enable DHCP on my router 3 for my LAN network.
I have 3 VLANs in my LAN network: VLAN 30, VLAN 40, and VLAN 50.
They all have to ping each other and the web server 64.100.100.10, the TFTP server, and the IT pc.
Here is the network file.
Thanks in advance.
Student HoGent
 You did everything right. The only thing I found missing was put the interfacce between the switch S4 and Router R3 in trunk mode.
11 Replies 11
ip dhcp pool MHM-30
network <VLAN-30>
default-router <VLAN-30 subinteface IP>
dns-server <VLAN-30 subinteface IP>
same for all other VLAN 40 & 50
Sorry I dont install packet tracer' I answer to your post title.
MHM
Hey @Flavio Miranda
Thx, I was searching for this for a couple of hours now, not finding what the problem was.
Thanks a lot.
 You did everyhing  right, congrats. This interface thing was only distraction.
Hey @Flavio Miranda,
What was the missing command, between S4 and R3.
So I can do it on my own next time.
On the interface  between S4 and R3 you just neet to run on the switch side
switchport mode trunk
But between S4 and R3 there is another switch S2?
On the interface with the arrow, you config as trunk mode
Okay thx, so it was on S2 and R3
ImogenHamilton
Hi, thanks! I was looking for this solution. I created DHCP pools for each VLAN by specifying an IP address range, subnet mask, default gateway, and DNS server, but I got an error.
 Create a new post, attach you project and I can help you. Just let me know
