Newly created SSID not showing - Flexconnect Access point
I have WLC 5500 and software version is 7.4.100. I am trying to join an access point(AIR-CAP2602I-E-K9) to the controller as a flex connect mode.It has been converted to flex connect mode successfully. Before joining as a flex connect there were 2 SSIDs and they are showing in Flexconnect tab --> vlan support--> SSID
When I created new SSID it is not showing under flexconnect tab--> Vlan Support --> SSID
Please assist
I think you are missing  In the Advanced tab, select the FlexConnect Local Switching check box to enable local switching for the WLAN.
for more information see this document.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-2/configuration/guide/cg/cg_flexconnect.html#wp1225108
Kazim abbas
