Nexus 3064 many Q-in-Q tunnels on interface
Tomasz Hinz
Hello there,
On nexus 3064 I can do Q-in-Q with following config:
nterface g0/10
switchport
switchport mode dot1q-tunnel
switchport access vlan 222
but I don't know how to do many Q-in-Q incoming tunnels on one interface.
I receive VLAN 800-811 in Q-in-Q vlan 222
and VLAN 900-945 in Q-in-Q vlan 223
Is this passible on this switch ?
Thank you in advance !
********************************* Comel - Tomasz Hinz
Iulian Vaideanu
Level 4
Level 4
I'm pretty sure it's not possible - I believe what you need is called selective q-in-q, which n3k cannot do.
5 Replies 5
Iulian Vaideanu
Level 4
Level 4
Because I have confirmation from other source about that, now I'm sure that is not possible. Many thanks !
I've only worked with NX-OS 6 on Nexus 3064 - after reading Georg's post I browsed through NX-OS 7 docs for Nexus 3000 series and found (in the Interfaces Configuration Guide) that vlan mapping dot1q-tunnel is indeed available.
I have some unused 3064s around and I could test this when I get some time, but I think it's safe to say that what you need is possible with NX-OS 7...
Georg Pauwen
do you mean:
switchport vlan mapping 800-811 dot1q-tunnel 222
switchport vlan mapping 900-945 dot1q-tunnel 223
You need NX-OS 7.x for this command...
TPL(config-if)# switchport ?
  <CR>
  access        Set access mode characteristics of the interface
  autostate     Include or exclude this port from vlan link up calculation
  block         Block specified outbound traffic for all VLANs
  dot1q         Configure dot1q EtherType value
  host          Set port host
  isolated      Disable loop-free detection.
  mac-learn     Disable/enable mac learning on interface
  mode          Enter the port mode
  monitor       Configures an interface as span-destination
  private-vlan  Set the private VLAN configuration
  trunk         Configure trunking parameters on an interface
TPL(config-if)#
TPL(config-if)# switchport vlan mapping 800-811 dot1q-tunnel 222
% Invalid command at '^' marker.
TPL(config-if)#
sh ver (ommited)
Software
  BIOS: version 4.0.0
  NXOS: version 7.0(3)I4(7)
  BIOS compile time:  12/05/2016
  NXOS image file is: bootflash:///nxos.7.0.3.I4.7.bin
  NXOS compile time:  6/28/2017 14:00:00 [06/28/2017 21:53:29]
