Nexus 7000 as MPLS Router
rajeshrajan1
I see that the Nexus 7000 supports MPLS and can be deployed as a MPLS router. Has anyone done this deployment?
Does it support BGP with MPLS?
Thanks!
5 Replies 5
Reza Sharifi
Yes, it does.  It supports MPLS/VPN and BGP.
Thanks Reza,
So it can support BGP or Multiprotocol Label Switching [MPLS] IP VPNs, as described in RFCs 2547 and 4364 like the 6500 and the ASR?
That is correct.  It is just matter of having the license and turning on the each feature.
feature bgp
feature mpls
etc....
Rajesh
You also need to install and enable mpls feature-set
Here is the config guide:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/mpls/configuration/guide/mp_feature_set.html
HTH,
Alex
arshapir
Absolutely, there is full MP BGP supportfor v4/v6 VPNs, 6PE and MDTs. You can reach out to me directly if you need more info.
Arkadiy
