Nexus 7000 (NX-M132XP-12L) and QoS statistics
kremeznoy
Hi!
I have such input data:
2xN7K-C7010 - Nexus7000 C7010 (10 Slot) Chassis
2xN7K-M132XP-12 - 32x10Gbps
NX-OS version 6.1(1)
I have enable (by default) QoS feature on them:
N7k# show policy-map interface brief
Interface/VLAN [Status]:INP QOS       OUT QOS       INP QUE       OUT QUE
port-channel1   [Active]:                            default-in-po default-out-p
port-channel2   [Active]:                            default-in-po default-out-p
port-channel10  [Active]:                            default-in-po default-out-p
Ethernet1/1     [Active]:                            default-in-po default-out-p
Ethernet1/3     [Active]:                            default-in-po default-out-p
Ethernet1/4     [Active]:                            default-in-po default-out-p
Ethernet1/5     [Active]:                            default-in-po default-out-p
Ethernet1/7     [Active]:                            default-in-po default-out-p
Ethernet1/8     [Active]:                            default-in-po default-out-p
Ethernet1/19    [Active]:                            default-in-po default-out-p
and so on.
But I couln't see any QoS statistics on both Nexus devices:
N7k#
show policy-map interface ethernet 1/1
Global statistics status :   enabled
Ethernet1/1
  Service-policy (queuing) input:   default-in-policy
    SNMP Policy Index:  301990537
    Class-map (queuing):   in-q1 (match-any)
      queue-limit percent 50
      bandwidth percent 80
      queue dropped pkts : 0
    Class-map (queuing):   in-q-default (match-any)
      bandwidth percent 20
  Service-policy (queuing) output:   default-out-policy
    SNMP Policy Index:  301990546
    Class-map (queuing):   out-pq1 (match-any)
      priority level 1
      queue-limit percent 16
    Class-map (queuing):   out-q2 (match-any)
    Class-map (queuing):   out-q3 (match-any)
    Class-map (queuing):   out-q-default (match-any)
      queue-limit percent 82
      bandwidth remaining percent 25
N7k#
Does anybody know why?
Good day.
Jerry Ye
How much traffic are you pushing through the interface?
jerry
Hi!
Now only OSPF is working through this interfaces - 6 point-to-point relationships. And also I initiate icmp-traffic functioning by using "ping"-command.
I think that I have to see some counter increasing by using command "show policy-map interface" like in this document:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/qos/configuration/guide/statistics.html
Good day.
Sergey
I read somewhere the M1 cards do not show any statistics, so the command "qos statistics" is quite useless.
