Nexus 7000 OSPF Max-metric Question
jleblanc
Nexus 7000 question. Normally when a command is hidden it indicates  deprecation in the next rev of code. That being the case what will be  the alternative command for "max-metric router-lsa include-stub  summary-lsa"? I don't like having to cost off interfaces its sloppy and  leaves room for human error. The current code only gives the option for  "max-metric router-lsa" but will take the other 2 as hidden commands.  Any help would be greatly appreciated.
Jason
paolo bevilacqua
Which kind of help are you looking for ?
Paolo,
I am basically asking why the 2 additional options for the max-metric command are hidden.  Is Cisco planning on deprecating them?  If so what is Cisco's alternative to costing off traffic without having to manually cost off each transit interface on the switch.  Thank you for taking time to reply.
Jason
