Bookmark
Subscribe
2402
Configuring HWIC-8A on 2911 Router
pstojanovski
Hey everyone,
I had purchased a HWIC-8A in an effort to provide terminal server capabilities into multiple routers. I had found a document that I thought would take me through the configuration but it doesn't appear that the command syntax is the same on the 2911's as it is in the document. Does any know how I would need to get this configured on the 2911 router?
Here is the document I was referencing
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a008014f8e7.shtml
I appreciate the advice and help.
paolo bevilacqua
And what commands would be different ?
For the ip host command, i'm trying to figure out the the ports 0/0/0-7 on the router translate to the numerical values listed in the document.
ip host 3600-2 2013 172.21.1.1
Richard Burts
Paul
I have not configured a terminal server on 2900 routers and there may be some differences that I do not clearly understand. But it is my understanding that the port numbers in the ip host command are in the form of 20xx where the xx are the line numbers 0/0/0 through 0/0/7 (2001, 2002, 2003, etc)
Rick
Rick
