nexus 7018 Ethereal
gopinathan.k
hi,
How to capture the traffic in nexus 7018 which is going via dataplane.
Jon Marshall
gopinathan.k wrote:
hi,
You are going to need to use SPAN to do this. See the attached configuration guide on setting up SPAN -
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/system_management/configuration/guide/sm_14span.html
Jon
jkilleda
Level 3
Level 3
Hello Gopinathan,
nexus 7018 Ethereal
You can use Wire shark also know as Ethereal , follow the guide given below which gives a detailed explanation on it's use.
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-7000-series-switches/white_paper_c11-554444.html
