Nexus 7K Configuration Questions
dmooregfb
Level 5
Level 5
I have several questions about the Nexus 7K. I am attempting to connect to a Nexus 5548 using a 10Gig interface.
I am using FINISAR 10Gbase-SR on both sides with 50/125um fiber. I am unable to get the interfaces up on either device. Is FINISAR a qualified transceiver? I am unable to find anything to the negative. Cisco 3 meter cables use CISCO-FINISAR type connectors.
Thanks ahead of time for any input!
Dave
The connection is from the 7K on Port e9/2 to 5K Port e1/3
5K -
interface Ethernet1/3
  description Fiber connectgion to Nexus 7009 --> Port e9/2
  switchport mode trunk
Nexus5000-1# sh int e1/3
Ethernet1/3 is down (SFP validation failed)
7k - VDC - Default
int e8/1 is connected to VDC2 to e9/1
7K - VDC2=Production Membership is e9/1-4
interface Ethernet9/2
  switchport
  no shutdown
Ethernet9/2
    transceiver is present
    type is 10Gbase-SR
    name is FINISAR CORP.
    part number is FTLX8571D3BCL
    revision is --
    serial number is AMF0S00
    nominal bitrate is 10300 MBit/sec
    Link length supported for 50/125um OM2 fiber is 82 m
    Link length supported for 50/125um OM3 fiber is 300 m
    cisco id is --
    cisco extended id number is 4
Ethernet9/2 is down (SFP checksum error)
  Dedicated Interface
  Hardware: 1000/10000 Ethernet, address: 6c9c.ed4e.b9c2 (bia d867.d901.2915)
6 Replies 6
huangedmc
Level 3
Level 3
While Finisar is one of Cisco's OEM manufacturers that produce their SFP's, you need to have a Cisco branded SFP for the interface to come up.
Nowadays the newer platforms perform a check against the hardware module to make sure it's Cisco.
If not, the switch would shut it down, which I believe is your case.
I was working to configure port channel for one of the 5k switch whare the 10gig port was not coming up.
here switch is detecting the part number is FTLX8571D3BCL-HP SFP but throwing checksum error.
we dont hav additional SFP on that site
Sw1#show Ethernet1/13
Ethernet1/13 is down (SFP checksum error)
Dedicated Interface
  Belongs to Po10
  Hardware: 1000/10000 Ethernet, address: 002a.6a5f.6534 (bia 002a.6a5f.6534)
  Description: #connected to # ta28cvmda01 #
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is trunk
  auto-duplex, 10 Gb/s, media type is 10G
Sw1# show interface e1/13 transceiver
Ethernet1/13
    type is 10Gbase-SR
    revision is A
    serial number is AQD0V6D
    cisco id is --
This corrected my problem: you can type "service unsupported-transceiver" which allow you to use non-cisco SFP's
Let me know
Thanks, dmooregfb
I got below warning but I can use the non cisco SFP now
5K05(config-if)# service unsupported-transceiver
Warning: When Cisco determines that a fault or defect can be traced to the use of third-party transceivers install                 ed by a customer or reseller, then, at Cisco's discretion, Cisco may withhold support under warranty or a Cisco
support program. In the course of providing support for a Cisco networking product Cisco may require that the end user install Cisco transceivers if Cisco determines that removing third-party parts will assist Cisco in diagnosing  the cause of a support issue.
hi
i want to ask, i have same problem when used sfp hp. interface status SFP checksum error
when i want put configure
N9K(config-if)# service unsupported-transceiver
this command cant support apply in interface.
do you have any suggestion about this my problems.'
thank
you can't do it per interface, go out to pre interface config and run same
