Nexus 7K licensing issue.
rajesh.kumar
Level 4
Level 4
We have Nexus 7018 is on production. Recently it is been configured.
When we issue below command, we get "License missing"
This means license has not been installed? we have purchased part#N7K-LAN1K9
NX-7018-SW# show license usage
Feature                      Ins  Lic   Status Expiry Date Comments
                                 Count
LAN_ADVANCED_SERVICES_PKG     No    -   Unused             -
LAN_ENTERPRISE_SERVICES_PKG   Yes   -   In use Never       license missing
**** WARNING: License file(s) missing. ****
Pls. suggest.
Try copying the license file from the stand-by switch to the active switch and install it.
rsimoni
yes, it must be installed.
Do you have a .lic file in your file system (usually in bootflash:)?
Try typing 'show license file ?' and check what you see
to install the license
install license bootflash:///.lic
and then you check again 'show license usage'
Riccardo
We have nexus 7018 with 2 N7K-SUP1
In standby SUP I can see .lic file, but in active there is no .lic file.
Is something wrong ? or shall I copy standby .lic file in active SUP and install?
dir bootflash://sup-standby/
        273     Dec 30 11:13:23 2010  TBM14481648_151640682.lic
      16384     Dec 30 11:10:58 2010  lost+found/
   99566941     Jan 02 13:19:43 2012  n7000-s1-dk9.4.2.6.bin
   23863296     Jan 02 13:12:53 2012  n7000-s1-kickstart.4.2.6.bin
       4096     Dec 30 11:50:31 2010  vdc_2/
       4096     Dec 30 11:50:31 2010  vdc_3/
       4096     Dec 30 11:50:31 2010  vdc_4/
dir bootflash:
      49152     Jan 15 15:42:49 2012  lost+found/
   99566941     Jan 17 10:36:00 2008  n7000-s1-dk9.4.2.6.bin
   23863296     Jan 17 10:35:26 2008  n7000-s1-kickstart.4.2.6.bin
       4096     Jan 17 10:42:53 2008  vdc_2/
       4096     Jan 17 10:42:53 2008  vdc_3/
       4096     Jan 17 10:42:53 2008  vdc_4/
Pls. advice.
Rgds
Rajesh
